5TB external library, analzye in Macbook Pro and Use to DJ on Ipad Air
I am traveling and don’t want to bring my controller or laptop. My main set-up is NI and I use a Kontrol S2MK3. I want to strip things down to there minimum. It was suggested to me to use DJay and an Ipad. I have a 2019 Macbook Pro and a brand new Ipad Air. I have installed DJay on both. I have the wires to handle the cueing and sending sound out, as well as charging and plugging in the 5TB hard drive that has some of my music (I know…it’s all FLAC and there is a lot…it’s kind of my thing). Anyway…I would like to analyze the tracks now on the Macbook Pro and then transfer the metadata files to the Ipad but use the external drive to house the actual tracks. I suppose I will need PRO to do this, as although I could add from my files the root folder, there was no way to point the analyze function at it or to add the root folder to the playlist area.
Any ideas on a workflow that might work best? Will PRO allow me to do this? Anything else I should be thinking about?
Thank you in advance.
I’m about to start analyzing on MBP… Anyone have recs… Do you think it’ll work?
Hi. Try this…
Thank you very much @Zirrex Should I drag the root folder to the “Playlist” area to “import” the songs into the library…then analyze them? And then go through this process…
