Love the program so far guys. Just a thought.
- You should add the ability to mark songs as played or unplayed like in virtual dj.
- You should be able to distinguish the difference between videos and mp3’s in playlists.
- You should add the ability to distinguish between spotify and HD songs when searching and the ability to remove songs from library in search.
Keep up the good work
