I can play spotify songs in Djay Pro that are already in existing spotify playlists, and using Spotify App works fine.
Only the Search Spotify feature is impacted - see screenshot.
Running latest 2.0.13 from 2 days ago, never had the issue before. Is it possible that the bug was introduced in the latest update?
I have a party with 100+ guests tonight, this is a MAJOR bummer.
OK, not too bad, I had to logout from Spotify and login back, and it fixed the issue. phew!
We are happy things are back to normal.
Please contact us right away via support@algoriddim.com if the problem is reoccuring.
Cheers,Lukas E.
