Ableton link fails in 5.6.7 release
  • HP Envy DV6
  • Windows 10 home
  • Version of djay 5.6.7
  • DJ CONTROL MIX
  • Ableton link provides a fixed value
  1. Ableton link on - Rekordbox translate it into midi clock - LoopMidi sends midi clock to Qlc+
C) EXPECTED RESULTS:
  • Qlc+ follows the clok and synchronize the lights
D) ACTUAL RESULTS:
  • With DJAY 5.6.7 Qlc+ receive from DJAY a fixed value of 499 milliseconds corrsponding to 120 BPM. The previous release worked fine
Hi @Tiziano_Dimastrogiov, thanks for the details about your setup and the issue - this is very helpful!
  1. Was this working as expected with a previous version of djay?
  2. Can you please share a video of how this behaves with djay and with Rekordbox for comparison? Thanks!
Yes, the previoua release works perfectly. Yes i Will provider a video rhis evening.
Thanks for confirming @Tiziano_Dimastrogiov. I’m looking forward to reviewing your video.
I uninstalled all the software (DJAY, RekordBox, LoopMidi, QLC+4) and cleaned out all the registry files using CCleaner. Afterward, I reinstalled everything, and now—magically—it works. I don’t know what happened, and honestly, I can’t say for sure if the problem was caused by the DJAY update, but everything is working again now. My apologies, and thank you so much for the assistance!
You’re welcome @Tiziano_Dimastrogiov. That’s great to hear! Thanks for the follow up.
