about audio copy
i have one more question
i understand djay only support aifc format for audio copy
would you teach me any daw app support aifc format for audio copy?
or
any app i can convert to wav without using pc
becouse it’s troublesome to use i tune file sharing
i think any of these app doesn’t support aifc format
http://code.google.com/p/intua-audio-…
This question is a bit tricky and cannot be answered straight up. While most music apps probably support AIFC playback, they may not support pasting compressed files.
Which specific apps do you have in mind? Have you tried contacting their support team to check whether the app supports pasting AIFC files?
