About the speed of the song relative to one rotation of the JOG on the DJ controller
  • Device model ALL DJ controller:
  • Version of djay 5.1.2:
On a real turntable, at around 130 BPM,
one rotation advances one measure.
When using Djay, even if I rotate the JOG on my DJ controller once, it’s slow, only advancing about 1/4 the distance of the turntable.
It makes juggling difficult.
Are there any settings I can change to improve this?
Was my question phrased inappropriately?
Check the time of the song that advances with one JOG revolution on Djay.
It’s slower than SL1200.
Is it possible to do the same?
When reversing a song with JOG,
I have to rotate it many times
It’s slow and hard.
Traktor lets you juggle with a controller just like you would a turntable.
Hi @megamema,
Thanks for sharing your question and the patience behind it.
By any chance, are you still seeing this behavior in the latest version, v5.2.8?
Additionally, what controllers are you using that you are experiencing this with?
hi,@NathanielAlgo
thank you for replying
ver5.2.11173.0
win11
・Hercules STARLIGHT(NORMAL)
・TraktorS2(with CustomMIDIMAP)
Both have the same behavior.
It won’t work unless you rotate it more than a turntable.
This was resolved by changing the Advanced Controls setting in the MIDI map.
Excellent! Thanks for the follow up @megamema. Glad to hear you were able to sort it out.
