If a TAD of a song has accents, it does not find them. It is normal? Thanks!
djay generally supports accents. Can you please let us know what version of djay you are using (e.g. djay Pro 2.0.11 for Mac)? Also are you referring to titles not being found in search? If so can you please give an example of a title with an accent?
Thanks for the additional info, that definitely makes sense to strip the accents before applying the string to the actual search. Are you seeing this search behavior on Mac, Windows, iOS, or Android?
Yes it looks with accents for example, if I want to look for “adiós” if I write “adios” it does not find me, I have to write it with accent.
The suggestion is to look for “adiós” if you write it with or without an accent.
On Mac
