I’ve always used iPhone and iPad with djay but now I have a Mac and will probably be my main source now…Ive noticed the cue points tend to shift or not the exact between devices. so if I set a cue on my iPad its not the same on the Mac or vice versa…THE FIRST PICTURE, CUE POINT WAS MADE ON IOS
THE SECOND IS FROM THE SYNCING AND ITS A LITTLE OFF
IS IT BECAUSE OF ICLOUD SYNCING??
Those has been happening a lot lately and I can tell you it’s not only from IOS to Mac,
I only use IOS and occasionally when I sync my iPad to update new tracks, I find myself constantly adjusting the Cue points to align with the beat grid.
Sometimes I also have to adjust the Beat grid as well
On the screenshots, the tracks come from different sources (1. Tidal, 2. local) - that makes a difference. If you use the same sources and the same audio files with the same settings on both devices, the problem should not occur.
both SS are from tidal, I just so happen to be in that folder
