acknowledging with 'keep' that the crossfaders have changed from default should give me back the crossfader.
If I acknowledge that the crossfaders have changed from their default then the warning should give me back the slider in its’ altered state. BTW even though the GUI won’t let me use the slider my controller will.
I changed one of the decks to “thru” I wanted it this way so I could use the cross fader the do visual effects without affecting audio.
Hi Daniel Conder,
thank you for your post. So in which state was the crossfader before you changed the crossfader assignment?
Thank you Daniel, I understand your issue now.
Forwarded and it would be great if other users could upvote the issue.
DJ pro automatically changes the crossfader assignment to use with the Spotify matching songs feature. (Left matches songs on deck 1, right… deck 2) Although the feature is attractive I prefer my crossfader as originally designed. There should be a way to toggle this behavior. It’s really annoying to not have my crossfader available when needed.
