Activate software manual FX from the Rane 70
although i have to admit that you did a great job integrating rane 70 with a great map , although i was able to map rene 70 with all my favorite functions to use with djay pro , i have to admit i would never use rane 70 with serato because it is really bad program but djay pro made this dream possible…however there is only one thing i can’t use from the mixer and that is the effects program . in fact I can use instant effects but I can not use manual effects . this is an important limitation because some manual effects are fundamental. I would like to suggest that you implement this feature because I think it is important to have the ability to trigger the use of manual effects via the mixer
  • it is not possible to activate manual FX from the Rane 70
0 voters
