Active Deck is only determined by Crossfader
Currently the “Active Deck” is only determined by the crossfader. Most of my Time I’m not even using my crossfader or it’s in the middle it would be nice if the “Active Deck” is not only determined by the Crossfader and instead on which deck is the current music is running.
Coming from Rekordbox this is a small “stepback”.
Thanks for the suggestion @mariusLAN! Our dev team is already aware of this and is investigating options for a future release. Thanks!
I have the same problem. In my case, the solution would be to make the active deck “the last deck to which a song was loaded”. This way, I could use all my key mapping without having to manually change the active deck (which is visually not indicated).
Thanks for the additional feedback and input @Manuel_Alejandro
Hi @mariusLAN and @Manuel_Alejandro, I’m happy to report that this has been addressed in djay 5.3.
For the full 5.3 release notes, please refer to the topic below. Thanks!
How was it solved? I can’t find it.
Same. Where is it mentioned?
Hi @Manuel_Alejandro and @eyeseeyou01
Other
  • Improved active deck selection for History, Match, and when starting Automix, switching to One Deck, etc.
  • Improved Match, history, and now playing track info when mixing with line faders only
Ah. I understand. I just tested it and it’s working. When the crossfader is centered, the active deck appears in the history when you stop the previous song.
Excellent. Thanks for the follow up
To be more precise, the active deck / selected deck is determined when the volume fader of the opposite deck reaches 0 or the deck is stopped..
As you all probably know the improved active deck selection works great! But unfortunately, since that improvement was introduced in version 5.3, the previous workaround—selecting the desired deck by pointing the crossfader—no longer works.
I used that feature a lot and would really like to keep using it, so I submitted this suggestion about it:
→ If you’d also like to continue using this crossfader function, please vote for the suggestion!
An alternative for Algoriddim would be to add a MIDI command, so we can reassign the crossfader to this function ourselves.
Any news on this one, @Slak_Jaw?
It would be super helpful if a MIDI command could be introduced for this, specifically to use alongside the crossfader, so we could ‘tell’ the Match function which Deck to find matches for.
Hi @DJ_Big_Blender, I don’t have any news on this. I recommend that you open a new suggestion topic for the additional MIDI command as this topic has been considered solved.
