Active loops on song load and automix
I have saved loops in my songs
On some songs a loop is active on load. This is cool, but I can’t work out how to set a saved loop to be active on load.
  • How do you do this?
When using automix active loops when you load songs are annoying because you have to manually turn them off each time, which defeats the point of automix.
  • How can I disable active loops on track load when in automix mode.
Hi @rishi, this is a global setting. Either it’s on or off for all Saved Loops #1. Navigate to the djay Settings>General>SONG LOADING. Please note that this only works for Saved Loop #1.
@Slak_Jaw Many thanks. Must have set that and forgot about how to do it
You’re welcome @rishi. Happy to help!
