Hello, I play djaypro on macOS with a monitor, why is it not possible on four deck to separate the waves like on 2 deck. There is room enough.
Hi @DjSille, welcome to the community! I’m not completely sure, but I suspect this is due to some kind of performance limitation with rendering that many waveforms in real-time. My guess is this would require a lot more processing power. However, let me check with the engineering team to see what they have to say and get back to you. Thanks!
I go B2B with other DJs — I use track 3 and 4 only to the dj 1000-
But I can’t get stem waveforms to appear on 3 and 4 .frustrating!
My B2B partner uses decks 1 and 2 connected dj 1000 on a diff laptop
Hi @DjSille and @Felix2, I’ve changed this topic from a Question to a Suggestion and shared this with the dev team for consideration. I’ll report back here when I have news. In the meantime, please use the blue vote button at the top left of the page. Thanks!
- Device model: Macbook Pro M1
- Version of operating system: 15.7.1
- Version of djay: 5.4.2
- Hardware/controllers used: Custom / Intech Studio modules / Propriety FW
I’m missing the ability to show stems in 4 deck mode more and more. It is not an option like in 2 deck mode. It is understandable, because 4 deck mode is already overwhelming.
- Maybe it is already possible to show stems in 4 deck mode?
- Proposal is to make it possible, compromise could be to just show stems for deck 1 and 2, leaving deck 3 and 4 simple.
- At least make this option highly configurable.
Cheers, Bart.
Hi @Brainbox, please use search before creating new topics. I have merged your new topic with this existing one. Please vote above. Thanks!
My temporary workaround, fwiw:
It is possible to seamlessly switch between 2 and 4 deck modes, and if you use 3 and 4 for prepared one-trigger samples, you can even load them on the controller to 3 and 4 in 2 deck mode.
Nice. Thanks for sharing @Brainbox
I would love to see this implemented, or even a 4 STEMs waveform in a 3 Deck Mode
Thanks for the additional feedback @mrchrischin
I recall being able to do 4 decks and 4 stems before, was the feature removed (or it could have just been a dream…)? Is there a way to rollback to that iteration of software if it was available at one point?
Honestly I don’t recall for sure @mrchrischin. I typically only use 3 STEMs myself. Either way, there is no way to rollback to previous versions of djay.
I don’t understand why they don’t do it like in 2 Channel mode. There you can turn it either on or off. Pleaaase do the same for 4 deck mode!!
Thanks for the feedback @DjSille
