Add ability to edit set history names.
Please allow the ability to edit the names in set history. This would allow us to put the venue name beside the date for easy searching of sets. :grin:
Hi @SamJam, do you mean the Sessions playlist names like β€œDJ Set - Nov 7, 2025”? If so, you can already edit these. See screenshots from iOS below:
On macOS, you can Double-Click on the playlist name to edit and rename it.
I did not know about the double click option. I will try this tomorrow. Thanks.
You’re welcome @SamJam
