AUTOMIX is a requirement if this is to be used for every day gigs. It should function just like on IPAD.
Hi @photos_inspace, welcome to the Community! Thanks for the suggestion! Good idea. I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
Hi again @photos_inspace, I spoke with our dev team and they had discussed whether you’d want to have Automix in a headset or not. The team is curious to know if you want to take off your headset and have the sound to continue playing or if you want to immerse yourself in the headset listening to a mix without having to do anything. Looking forward to your follow up!
The sound should follow the normal path it does now. If you cast to a device that lets you output the audio like a Smart TV you can take that signal and put it to an amplifier or other device.
Once automix is enabled it just keeps going headset on or not.
Excellent. Thanks for the additional info @photos_inspace!
