Add Bit Depth & Sample Rate columns to library
For optimal stems/neuralmix functionality it’s best to work with hires audio files (24 bit with 96/192 kHz sample rate). For this it would be very useful if additional tag columns like bit dept and sample rate could be added when seeing a library (like my local music library) in Djay. So it’s directly visible what the sound quality of a music file is.
Hi @troolos, welcome to the Community! Thanks for the suggestion. I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
i @Slak_Jaw , thanks for your respons. I’ve seen there is a wau to select Sample Rate and Bit Rate as an additional column. Selecting the Sample rate gives me some information (if this is 96.000 or 192.000 kHz it’s 24 bit depth (Hires). Only the attribute “Bit Depth” is not available in the dropdown list to select (see attached screenshot). It would be nice if this attribute could be added.
Thanks for the additional info @troolos
