Add BPM count to DVS Thru Mode
Hi!
The new Thru Mode is great! It works perfectly with most of the effects, which is great. Unfortunately, there is no BPM count. When I use two decks in Thru Mode, I can’t use the looper in a good way as there is no “master tempo”.
Would it be possible to count BPM in Thru Mode, perhaps using the last 4 or 16 beats?
I think you can use the midi “tap for BPM” for effects. I haven’t done it in a gig yet but it seemed like that was the case. Gonna follow this thread to see what devs say.
Thanks for the suggestion @Christian_N. I have forwarded this to the dev team for consideration.
Hi again @Christian_N, if you have a spare MIDI controller button you can map the FX BPM tap and get it in sync manually.
