kev0329
1
Is it possible to add your own visuals for instance like a dj logo visual.
can the visualizers in the program be set to random instead of having to go thru menu and managing changing per song
Hi @kev0329, welcome to the Community!
- You can add custom Text overlay and custom Image overlay (see linked user manual section below)
A. Video mixing | Algoriddim Support
- You can also use videos and images stored on your device.
A.
- Currently, you need to manually change the visualizers - randomization not supported.
