Add "Date First Played" library column
YOUR SUGGESTION:
So, there could be an option to display the first time it was played, because that way we could keep the date that was allocated and the date it was played for the first time without losing the information. This option would be very useful. I believe our Djay engineers could easily implement this. Those color boxes would also be amazing if they were included, because they don’t appear in OneLibrary.
image1911Ă—1032 167 KB
Don’t forget to vote if you think it would be a good idea.
Hi @MarcosAraujo, can you please clarify your suggestion? Are you requesting a “Date First Played” column? Or are you requesting a Color Tag column?
Both options will certainly be welcome.:wink:
Thanks for clarifying @MarcosAraujo.
We already support color tags on macOS. There is also an existing suggestion topic for adding color tags to iOS if you’d like to go upvote it:
