With Djay Pro on iOS it would be great to be able to move playlists that have been created to a different folder, to assist with a maturing collection.
Currently, with version 5.2.4 you can:
1.) Create either a playlist, a smart playlist or a playlist folder.
2.) Create a playlist or a smart playlist in a given folder.
3.) Rename an existing playlist or smart playlist or a playlist folder.
4.) Delete a given playlist, smart playlist, or playlist folder.
What would be great would be to be able to drag n’ drop (move) a created playlist, smart playlist or playlist folder to somewhere else in the existing structure.
From what I can tell through testing, in order to “move” a playlist from one folder to another you have to first create a new playlist in the new location, import all the tracks into that playlist from the old one, and then delete the old one.
As a use case, if you’re trying to “archive” (for example) 10-20 playlists from this year into a new playlist folder called “2024”, you’re going to have to manually create, import and delete up to 20 playlists to achieve the same thing.
Definitely a Quality of Life function I think.
Thanks for your consideration.
Kind regards,
James
