Add FX Combos: Echo-Filter-Roll and other FX Rolls
Please add the effect combo Echo - Filter - Roll and other creative rolls.
Thank you
Hi @Oscar_Castro,
  1. Can you please provide more details on this suggestion?
  2. Is there a similar effect on another DJ software that you’d like replicated in djay?
  3. With djay’s Manual FX, you can already chain up to 3 FX together. Perhaps something like Echo + Auto Filter + Looper will achieve the result you are looking for.
Thank you for your response. This is close but not exactly what I had in mind. The suggestion comes from Serato when I had an NS7III using the filter dail.
So as you would turn the filter dial, you could increase the filter, roll, and echo and increase it or decrease it based on how much you turn the dial.
With this image, only the intensity can increase but the number of beats never increases or decreases by turning the filter dial. All the effects and beat lengths are should be changed by the filter dial.
@Oscar_Castro I believe you could achieve what you’re describing by customizing the MIDI mapping. Using the Duplicate feature within the MIDI Learn tool, you can assign multiple MIDI commands to the Filter knob. In this case FX 1 Parameter, FX2 Parameter and FX 3 Parameter.
I’ve made similar custom Filter FX MIDI Mappings for my personal controllers in the past. It’s actually pretty straightforward to do.
Thank you for your response and expert advice. I appreciate your suggestion and this should help others as well.
You’re welcome @Oscar_Castro. Happy to help! Just let me know if you have any questions during your custom MIDI mapping.
Have a look at the macro effects as well that you can assign to pads - Hands Up, Jet Stream, Hydrant. One pad combos.
