Add Latency Settings for MacOS
Was going through the Djay pro settings menu for macOS and realized that the latency section has been removed. Any reason why that was done? I was able to get the app to be more responsive to my quick actions with a very low latency on my Mac but now that it’s no longer there I feel as if I am not getting the same response.
Hi @Zigla, this is only available within the DVS settings (audio buffer size 64 - 512)
@Slak_Jaw …Ok Thans for letting me know. Does this mean latency settings are only available for DVS?
Does this also mean that latency in djay pro is global and depends on the macbook/laptop that one is using? I am asking all this because i feel like djay pro is not as slick and responsive for my quick routines as i would like compared to the others.(Scratching and release is perfect. But finger drumming cue points while moving the crossfader quickly can sometimes be a bit off. )
HARDWARE I USE : CDJ 3000 + DJM - S11
LAPTOP: 2021 Macbook Pro M1 Pro 16gb
You’re welcome @Zigla. Latency is handled different on macOS (CoreAudio) than on Windows with ASIO drivers. I believe Buffer Size and Sample Rate are handled internally in code. Have you ever set the buffer size? If so what value did you use?
Example of Windows ASIO Latency settings:
where did you find that menu @Slak_Jaw ?
This is from a different software on a Windows laptop with ASIO drivers. I posted it as an example.
@Slak_Jaw , The previous Buffer Size i set on Djay Pro was 64ms (probably from the DVS menu). But on other software i have set it to the lowest possible without giving me a glitch in audio output. (Serato is set to 1ms, Rekordbox is set to 1.6 , Virtual DJ is set to 192). With these settings i am able to get the swiftest response when i am performing etc etc. Thanks. Maybe Djay pro should consider adding that as an option for its users?
Thanks for the details @Zigla. I’ve passed this onto the devs and have changed this topic from a Question to a Suggestion so that you and other users can upvote to have Latency settings added to macOS djay.
I’ve read a lot of old post here and it doesnt address that DJay does not have a buffer size that you can adjust to help with Latency, and DJay has a latency issue? can some one tell me what buffer size DJay is operating under? Ive set my Serato at 5ms Buffer size
That’s a very smart question. I know there’s a late xy setting for dvs on iPad. That I know for sure
Hi @eecy_cee, I assume you are on macOS? I have merged your new topic with this existing suggestion topic. Currently, we don’t offer buffer/latency settings on macOS unless you are using DVS. The dev team is looking into this option further. Please use the blue Vote button at the top of this page to show your support for this suggestion. If you are using Windows and ASIO drivers, we do have buffer/latency settings there. Thanks!
thank you Slak_Jaw I appreciate the response:)
You’re welcome @eecy_cee
So it means yet we can’t scratch properly on djay pro os with a controller like Flx10 or RANE performer?
I tried rekordbox, serato and djay pro on my flx 10 and for scratch, serato and rekordbox are perfect but djay pro has a bit of latency that makes it impossible to scratch with. I see on videos that it’s perfect with dvs but I would like to scratch with my controller and it’s not clean enough… there’s so much great things on djay pro but for this specific thing it’s a no go… same with stems latency when keylock is on
I checked different topics and see there’s something about iCloud sync. Do you think it can be related? I disabled iCloud sync and will check in a few days if it works better.
Hi @GrumpyCat, try turning Keylock Off.
Hello I’m asking for a feature request. Can you make pro dj adjust the audio latency with a slider and also choose the best sample rate for your device / controller in the audio settings window.
Hi @AMG2025, welcome to the Community! Please use search before creating new topics. I have merged your new topic with this existing one. You can use the blue Vote button at the top left of this page to show your support for this feature. Thanks!
