Add MIDI command for Qbert Scratch Tools
How do I map MIDI to the scratch tool? I can’t find the scratch tool option in the MIDI mapping configuration.
Thanks,
Joseph H.
  • Device model: 2024 iPad Air 13" M2
  • Hardware/controllers used: Rane Mix72 mk2
Hi @Joseph_Hsieh, I believe the commands you are looking for can be found in the JOG WHEELS section for each deck.
Sorry, I should make it clear. I mean the option for Qbert Scratch Tools, for which I must long-press the loading track to enable the popup.
There is no MIDI command for that feature. However, I have changed this topic from a Question to a Suggestion and will forward this to the devs for consideration. In the meantime, please use the blue Vote button at the top left of this page. Thanks.
