On the tablet as you can see the loop length is 128 on my Reloop beatpad2 controller on the other side with SHIFT only the pads from 16 and 32 light up, from 64 and 128 the pads do not light up and simply 64 and 128 are not
I’m not sure that I completely understand the issue here. To help clarify, can you please try to capture a short video of the issue and upload it here? Please note the maximum file size is 200MB, so if your video is larger than that, you’ll need to upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the file here. Thanks!
the capture is in the photo, the loop length 64 and 128 is only available on the tablet on the controller, not only up to 32, the pads for loops 64 and 128 do not light up, there is simply no MIDI command. RELOOP BEATPAD 2 controller
Hi @Jaroslaw_Szkudlarek, I have moved your posts regarding larger loop sizes to a new topic to help keep the conversation organized. I think I understand you correctly now. You want us to add MIDI commands for Auto Loop 64 and Auto Loop 128. Is that correct?
that’s exactly it, on a tablet loop 64, 128 is possible but on a controller there is no such possibility to run on pads
Thank you in advance
pt., 11 kwi 2025, 18:50 użytkownik Slak Jaw via Algoriddim Community Forums
no-reply@algoriddim.com napisał:
Great! Thanks for confirming @Jaroslaw_Szkudlarek. I will pass this onto the dev team! In the meantime, please Vote at the top left of this page. Thanks!
After updating to 5.3.1 it is still not possible to run LOOP 64, 128 from pads on the RELOOP BEATPAD 2 controller
Correct. This was not a part of the 5.3.1 release @Jaroslaw_Szkudlarek. Thanks for checking in.
well yes
in which update version will it be added? And by the way, this
listening to the prepared song has a chance to exist correctly. It would be
necessary for me and my colleagues by June 30 because we are starting with
the outdoor holiday season (program)
niedz., 20 kwi 2025, 14:30 użytkownik Slak Jaw via Algoriddim Community
Forums no-reply@algoriddim.com napisał:
Hi again @Jaroslaw_Szkudlarek, thanks for continuing to push this suggestion and sharing your feedback. In general, Algoriddim does not share timelines or roadmaps for djay development. Essentially, new features are only announced when they are completely ready and released in a djay update. All user suggestions are considered and carefully evaluated, but not all can be implemented for various reasons. Please refer to the attached discussion for more details. Thanks! Update to Our Voting System Guidelines [Suggestions]
2 posts were split to a new topic: Beatpad 2 Microphone issue
Hi @Jaroslaw_Szkudlarek, this sounds unrelated to this topic. Can you please create a new topic for this so we can properly track the issue you’re experiencing? Thanks!
17 devices are to be used in the program route, none of us has time to start new topics, we are not testers, we bought native equipment, we use paid subscriptions from dedicated Djay software and something is still not working and we have been waiting to listen to the prepared song since June 2024, dozens of emails and nothing. I am sorry but the situation is annoying and incomprehensible
Hi @Jaroslaw_Szkudlarek, I understand your frustration and I am here to support you. However, to provide effective support and to make sure things don’t slip through the cracks, we need to keep these discussions organized and on topic. I hope you can appreciate and understand that.
I am not a tester I pay for a complete product Djay application works on a
native RELOOP BEATPAD2 controller controlled by Lenovo M11 with android 14
Djay 5.3.1 update problem with the microphone, after turning on the switch
on the microphone the background music is very quiet, how to bypass it. I
do not have time to create topics and tests. I work on this and recommended
as PROLINE.
wt., 22 kwi 2025, 12:27 użytkownik Slak Jaw via Algoriddim Community Forums
Hi @Jaroslaw_Szkudlarek, this should now be fixed in the latest 5.3.3 release. Thanks!
At the beginning after checking it is better even though the limiter cuts but this is its role:) the microphone must be set to 13:00 and it is quite legible and correctly with the color. Thanks a lot, but it still needs to be refined in the future, but it is usable as of today. I greet you and ask for such positive corrections
You’re welcome @Jaroslaw_Szkudlarek
