Add new MIDI mappable commands for Prime Go
Thanks Slak,
I downloaded that App for my iPad and whilst I have it connected to my Denon Go, There are 5 buttons that when pressed send and receive a midi signal in Midi Scope but when I open Dj Pro and press the same buttons in the Midi edit mode, No signal is being received.
Is there any way that I can get these buttons to respond in Dj Pro?
Te buttons are;
Mic 1 on/off
Mic 2 on/off
FX Assign 1
FX Assign 2
FX On/Off button
This would be handy to have so I could map these buttons to other functions
Hi @maurizio_T, this is typically done in code to accommodate advance functions or to prevent unintended behavior in djay.
Thanks for the reply, so basically I can’t do this myself…
Any chance you could bring this up with the Dev team for future updates?
Not a deal breaker for me but if it’s not a huge job to do on their end, then yes it would be much appreciated.
Basically yeah, unless you want to have a go at editing the XML file. Please create a new suggestion topic for this and I’ll pass it onto the devs. Thanks!
Unless someone on here wants to give me some pointers on how to edit the XML file, I might give it a miss.
I know it can be done because one of the Midi maps that was released by either Geronimo or Jipenade in a version prior to the official Djay version had some of those buttons mapped…
Thanks, I’ll start a new thread in suggestions
Hi again @maurizio_T, I have moved this to its own Suggestion topic and passed this onto the dev team for consideration. In the meantime, please use the Vote button. Thanks!
Thanks Slak much appreciated
No problem! You’re welcome @maurizio_T
