When you are doing a mix, the screen shows a red circle, there is plenty of space below where you could show the length of time you have been recording
for.
I think that would be an easy enhancement.
for.
Thanks for the suggestion @David_Bielby! Good idea. I have forwarded this to the dev team for consideration.
Cool, i often check the time as i have a group of friends where we share mixes on messenger and the max is around 20mins long.
It would also be good for ‘club’ dj’s who have a set time of say 60 mins to know where they are
I am aware of this, which is why press 3 buttons to get this info when it can just display it.
The frustration is having to check at say 15 mins, then 18 mins then 20 mins, when it could be just there
Understood @David_Bielby. Just wanted to make sure you were aware of that just in case you weren’t. Your suggestion has been shared with the dev team for consideration. Thanks for the additional input.
