Correct me if i’m wrong but why does Djay not have the simple function to find the last loaded/currently playing track in its "current playlist"?
- In Serato you press [Control + L] to “Locate last loaded track (press again for other deck)”
- In iTunes you press [CTRL+L] to “Go to Current Song”
- Sometimes i change playlist and when i go back to the playlist i was using i have to scroll down a lot and sometimes its hard to find the song im currently playing
Has anyone found this problem and is there a workaround?
