Please could the developers consider adding native support to be able to broadcast (stream) the output of Djay Pro (on iOS in particular) to a Radio Streaming service that supports Shoutcast and Icecast?
I’ve noted 12 topics on this subject through the search across forums dating back up to 12 years, this is something that has been asked for a lot.
In this day and age where there are so many mobile creators, being able to broadcast “simply” is becoming more the norm. On MacOS and Windows this is much easier due to there being many well supported programs that can be readily used alongside Djay Pro, this is more of a suggestion for iOS.
I note on the Apple App Store there are very few decent Icecast streaming apps, with the only two that are really worth their salt being extremely expensive, with an additional subscription attached to boot!
Also, using iziCast on iOS (and one or two other similar apps) I note that the Reloop Mixtour Pro isn’t detected as an audio device, only the internal iPad microphone (iPad Air M2).
Thanks very much.
Kind regards,
James
