I use a number of radio jingles, sound effects, and short non-music audio saved as sampler files files that I mix with music in the Mac version of djay. I would like to do the same with the djay 2 for the iPad. How can I transfer these files to the iPad?
You can add your own samples via iTunes File Sharing. Simply drag and drop the files into djay’s File Sharing section.
