It would be nice if there were additional options for the crossfader curve, with support for ‘thru’.
The ‘crossfader cutting mode’ option could be removed and replaced with the three most common modes: thru, blend and cut. In addition the curve could be further customised with a knob.
This could be extended to the channel faders as well.
This feature is so desperately needed now when using Djay with a controller.
It is far too much hassle at present having to navigate through the menus to find ‘Cut’ mode on the crossfader when you want to have a quick scratch.
The software/app needs a button/switch on the main screen so this can be quickly toggled.
Please add this to the next update.
