- Hardware firmware version (e.g. 1.0.1):
- Please consider sharing a short video or screenshots to help clarify your question
YOUR QUESTION:
Hi there! Is there any way to change the loop in the same pack like in Windows?
For example in Windows there is the Latin House Pack, and there are Drums 1, Drums 2, Drums 3, Drums 4, etc. But in the android version I’m stuck with the same 8 loops.
Can I change them?
Hi @Rodri778, you should be able to download additional Looper Packs on Android if you have an active djay Pro subscription. Simply select the popup menu with the name of the current Looper Pack then select from the available options or press Get more Packs. I hope that helps.
For more info on using a single djay Pro subscription cross-platform, please refer to the linked FAQ below:
https://help.algoriddim.com/hc/en-us/articles/12806719766684-Using-Your-djay-Account-Managing-Subscriptions-Cross-Platform-Access-and-Legacy-Support
Yes, I already know there were additional packs, thats why I said that in the Latin House.
I meant like in the image, in the same loop there are 6 different versions of the loop, but in android version there are only 1 version.
Thanks for clarifying @Rodri778. This is a current limitation of the Android platform.
