From design point of view these are OK, but from practice point of view not. There is plenty of space to put plus and minus a little bit higher because they’re almost invisible when you need quickly adjust the grid as shown on the attachment. Just my humble opinion.
Hi @Gabriel_Boros,
- Can you please clarify what you’re suggesting? From the image you shared, the +/- buttons are for Pitch Bending not for Beat Grid Editing.
- The Beat Grid controls are located in a different menu.
- Also, please confirm what OS you are using (Windows, macOS, iOS, Android).
Apologies. Yes, you are correct. My bad. I meant the pitch control.
Not using Mac often so can’t say how’s it working there. Playing through iPad, so iOS.
Again, sorry for the confusion.
Thanks for clarifying @Gabriel_Boros.
- I have adjusted the topic title accordingly.
- Can you please also confirm what version of djay Pro you are running?
- Also, what UI Mode (Classic, Pro, 4 Deck, etc.) are you having issues with?
- Are you using the iPad in portrait or landscape orientation?
- Thank you @Slak_Jaw
- The latest available 5.0.3
- Pro and Automix
- Landscape mode on iPad Pro 12.9inch (6th generation)
Thanks for the additional info @Gabriel_Boros. I have forwarded this to the dev team for consideration.
