Here is my setup:
IPad 9th generation
IPadOS Version 18.4.1
Djay Pro Version 5.3.1
Mixer: Pioneer DJM-S7
Rane 12’s Turntables/controllers
When I am mixing two tracks and I deathmatch them perfectly without using SYNC, one of the tracks starts to drift out of sync on its own. I was a Traktor user before I started using Djay Pro and this never happened. Any help would be greatly appreciated.
Thanks!!!
Hi @Dj_SaBa, welcome to the Community! Sorry to hear you’re experiencing this issue. Can you please try to capture a short video of the issue and upload it here? Please note the maximum file size is 200MB, so if your video is larger than that, you’ll need to upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the file here. Thanks!
The first question is whether you have used Traktor with the otherwise identical hardware. Furthermore, it is almost impossible to manually adjust the tempo of two tracks 100% without having to make at least slight corrections sooner or later. If your tracks are clearly out of sync after just a few seconds, this is of course a problem, which may also be due to the hardware - which leads to the question posed above.
I have no personal experience with Traktor, but for me it works no worse with Djay Pro than with vinyl.
