Hi, I’m having a really hard time trying to convert the AIFC format to MP3 or WAV, could you kindly explain to me how to do it because I just can’t figure it out. I’ve already downloaded several apps and non of them seem to recognize that format, I’m very frustrated at this point. Thank you.
Hi Chava,
I recommend exporting the mixes to your Mac/PC and then you can convert the songs using iTunes.
Yeah, I guess I am going to have to do it like that, the problem is that I wanted to do it directly from the iPad, without having to connect to the computer, it’s not convenient. Thanks anyway.
I feel the same way I would like to be able to conver right from the ipad instead of connecting to a Mac first since I’m always on the move and not carrying my laptop with me always
