Airplay connection
windows 11 PC:
Hi, just downloaded Djay pro for the first time using on windows 11. Is airplay available so i can to connect to Sonos speakers, and if so where do I find it in the app?
Thanks in advance,
J
Hi @jjeremyl,
Thanks for sharing your question in our community!
Since AirPlay is a feature native to Apple devices, it is not available on Windows PC’s. However, there are different 3rd party tools and software floating around that may aid you in this journey that we do not officially support thus preventing our team from recommending said workarounds.
Apologies if this has inconvenienced you!
