Album as playlist
Thanks for adding me to this group. Apologies if this is a well-worn question. I have searched but can’t find the answer I’m looking for.
I would like to be able to play an album in full and in original order from time to time in DJay.
This would save me having to close DJay and go to another app to play an album.
Is there a simple and quick way to do this? To turn an album into a playlist an then play it seamlessly?
I’m using an iPhone 15 Pro.
many thanks
Andy
Yes, you can do this in djay Pro
  1. Create a playlist with tracks in order.
  2. Load 1st track.
  3. Turn on Automix.
Notes:
  • Turn Automix shuffle OFF.
  • Set transitions in Settings - Automix.
Thanks for the solution @Michael_Wisniewski.
Hi @AndyCopeman, can you please confirm that this answers your question? Thanks!
