What do you guys think the new, exciting feature is? Dynamic beat grids, done. Crossfader effects, done.
The only thing I can think of is the ability to add your own loops to the sampler section making the app closer to being a whole production suite. Since those other guys did the whole drum replacement thing. DJAY PRO has always been ahead of the curve.
Or, something AI. Don’t know what that could be though.
Or, the ability to rearrange the structure of a song with the push of a button. Like jumping to the break beat after an intro automatically.
I would vote for stability. New features are nice, but still there are plenty things which come to mind on what can go wrong during a gig / overall usage. And that’s sad, really. You start to kinda work around potential problems. I’m also a fan of djaypro and I stick to it, but stability wise it’s still so behind it’s competitors sadly… so i vote for the stability feature
Probably would have to agree with this as well,
I mean we do have enough features built into this great software already, Extra tricks isn’t going to make you a good or better Dj,
I would like for them to work on some of the easier suggestions that have been asked for multiple times,
Yes innovation is good, but sometimes too much of a good thing isn’t necessarily the answer
Well, maybe they’re working on a partnership with Alpha Theta to create flagship devices like they do with the other software companies. That would be SUPER DOPE.
The the ability to pre program auto mix to incorporate hot cues, loops, fx etc to perform mixes for you as you would yourself or something awful like that.
I think it will be hardware related. Imagine a device, with lots of assignable buttons. Hot cues, samples, fx, not in layers but available all the time. No jog wheel, just a strip of something so you can scratch.
hmm in the insta post, they mentioned a similar milestone like from vinyl to digital… think it will an similar addition like neural mix… maybe transform a track completely mood? some thing to change easyly a base drum of a track?
I still have been absolutely dreaming of a built-in DAW that lets you edit mixes after the fact; there are times where I cut too early, activated the wrong effect, beat jumped too far, or forgot to bring the low end back.
I am not a performing DJ, I exclusively prerecord mixes and post them online. I am also an unrelenting perfectionist and have gone back and re-recorded entire mixes from scratch over 5 times to iron out any mistakes.
I also frequently forget to record mixes and regret that afterwards. If Djay could record any moves or changes the user makes in a mix in a compact data structure and save it automatically, it could theoretically recreate the mix and export it after the fact, even if the user did not hit record. This especially would be a godsend, and I believe could even drive Rekordbox loyalists over to Djay.
This kind of functionality would be an absolute lifesaver and I would kill to see it added someday.
