All of audio going to one channel(Numark Mixdeck(2channel).
All of my audio is focused on one channel
as a master channel. Pls help
Hi Eros,
can you tell us what you want to achieve? Do you have problems with the pre cueing?
thank you for your mail, can you send us a screenshot of the mid mapping window showing the not working commands?
I am sorry to hear that, can you contact us via support@algoriddim.com for further help?
I am trying for it to work as 2 channels(since it is two channels), but MIDI leard isn’t letting me map the mixer section(crossfader, upfaders, highs, mids,etc…)its just uses channel 1 as a main master out, in other words, it uses channel 1 to control highs, mids, and lows of both decks
cant use the crossfader, cue channel changer, and gue gain
its the same as this topic (http://community.algoriddim.com/algor…)
but i dont have a mixdeck quad to use
I know how to map it, but MIDI learn isn’t picking up any signal from the mixer section, but when I use the controller with serato, or virtual dj it works fine.
