Bonjour, Quelqu’un utilise t-il une Xone DB4 avec Algoriddim ? Mapping, problèmes astuces ? Je suis sur Macbook pro Sonoma 14.7.1 Merci
English Translation:
Hello, Does anyone use a Xone DB4 with Algoriddim? Mapping, problems, tips? I am on Macbook pro Sonoma 14.7.1 Thanks
Hi @DjFilou, please note that this hardware is not natively supported on macOS.
However, if it does send standard MIDI commands, you should be able to MIDI map it yourself.
hi, i’m regular work with db4 all mapped for drive all my djay function incl sampler neural etc, but based on windows . Db4 works with win driver asio without problem.
i had also used db4 with dvs config and djay working flowless.
https://youtube.com/shorts/zVKYfMlCBXk?feature=share
Excellent. Thanks for sharing @carletto_dj.
