- Device model: Macbook Pro M3 Max
- Version of operating system: macOS 15.6.1
- Version of djay : 5.4.4
- Hardware/controllers used: FLX-10, CDJ-3000 and LC6000
I have noticed that when I change the tempo range on one deck, it is changed on all decks. For example when I change the pitch range on deck 1 from 6% to 10%, it is changed to 10% on all decks. I think I can get used to it but I don’t really like it. How can I turn this off?
Hi @caster25, this is expected behaviour with djay. There is no setting in djay to change this.
can we get this as a suggestion?
i use “wide” tempo range alot to do transition,
last night while playing i’m accidentally touch tempo slider on the playing deck and the tempo goes super fast hahaha.
separate tempo range for each deck would be great.
thanks.
Well yeah I think it’s a great suggestion. At least to have it configurable
yeah, make it configureable for each deck would be great. hope @Slak_Jaw send this suggestion to the dev.
Hi @holzakontra and @caster25, I’ve changed this topic from a Question to a Suggestion. I’ve also updated the title accordingly. Please Vote above so we can gauge user demand for this. Thanks!
You’re welcome @holzakontra
Yes, also voted! Would love this functionality!
Thanks for the vote and feedback @caster25
