Please add a dialog that confirms you really want to exit DJay even when nothing is playing. Command Q is one key away from ALT Q. If I am trying to set a start point and accidentally do Command Q suddenly my program evaporates and I loose Queued Songs and current History.
Hey Daniel Conder,
thank you for your feedback. Would be great if other users which are using the same workflow share their feelings towards the topic.
