What more can i say than it’s an excellent tool that makes it fun to mix.
As someone who has learned to master the old way of mixing 70’s and 80’s-music manually with the ears, using a tool like this has opened up endless possibillities using a controller, seeing the waves scroll by makes it supereasy, giving me the extra time won, to use the loops and effects to its fully potential and create segues never heard before. Thanks!
Thank you for your feedback and support. Really appreciate it!
I’d like to add that now… with the new beatpad screen layout where you can see the enabled effect and the loops, it is an even better tool! Many thanks for improving djay2!
