hello
great i can see the House Now Tidal playlist ! so i add it to Djay internal playlist so that i can manage it internally… but … it is still not possible to analyze the songs !
can you implement this quickl please ?
regards
Oh yeah
i’ve just tried but :
1.how can you add all song? I didn’t find…
2.how do you set a max song play duration ?
regards
What I do with spotify playlists:
- add all new songs to “automix playlist”
- depending of your internet speed set max song play duration to 40s-1min
- and let the automix roll
=> all songs should be analyzed
Sorry, didn’t notice that you use iPad DjPro version
I’m on DjPro 2 on mac.
Anyway if you have automix feature on the app (at least some kind there is based on documentation) , just let it play the list while you sleep for example
Just wanted to let you know the ability to pre-analyze entire playlists in the TIDAL library (analyzes BPM, key, beat grid, and waveforms) has been added in the latest versions of djay Pro AI for iOS (version 3.6.7), djay Pro AI for Mac (version 3.0.9), and djay Pro for Windows (version 1.0.27707.0).
Thanks to all of you for sharing your feedback here and for your patience. Happy mixing.
