When browsing playlists, where it states the number of songs, I used to click on that and it bought up an analyse all songs selection, in the latest update (1.4.1) the analyse all is missing. It now shows ‘add all to queue’ and ‘remove all from queue’?
Yes, I use Spotify, can you please add the feature back!! I’m used to having this, I understand adding features but removing them is confusing to say the least.
I only use Spotify not iTunes so taking this away is making the app worse IMO…
It was definitely implemented before, hence why I started this thread, I noticed it was missing and I had been using it for months…Why would have I asked this in the first place.
I feel like you’re now backtracking on the matter now and trying to make me look like an idiot!
You know it was there before and are now stating it wasn’t?
Wondering what happened in the end to this thread. i also remember for certain being able to batch analyse my Spotify playlists. I used them quite extensively (for about a year every weekend) and would always start them analysing a few hours before my show as I would tether to my device and it was much faster to load tracks.
Will this feature be reimplemented?
Cheers
EDIT: Found it!! Has been moved up to the ‘Library’ Menu up the top. If have your desired Spotify playlist selected on the screen and then go up to 'Library -> Analyse" it executes the same function as the old one that was located in the song count.
