Right now Playlist creation is seriously broken:
When you create a playlist in “My Library” by moving a Spotify playlist to the upper panel, none of the songs get their BPM & Keys in the newly created playlist.
Even when trying to Analyze, by selecting Analyze in the library menu, when clicking on the “start” button, it ends immediately, and nothing has changed in the playlist.
Can you fix this?
Regards,
Marc
Jean-Paul, I assume this thread is still related to djay Pro 2 for Mac. Analyze library has been improved to support custom playlists a while ago. I just double checked on the latest version and it works fine. Please note though that songs from Spotify can’t be analyzed offline, as they have to be loaded onto a deck for analysis to be triggered.
Video would be very helpful. Can you also please confirm that all songs in the playlist you are trying to analyze are songs from iTunes (and none of them from Spotify)? Thanks in advance.
