is there a way to only analyse tracks that haven’t been done yet?
I could be wrong but I don’t think so… Think the only way to analyze it is to load it other wise you would have to create a playlist and add those songs to a playlist then analyze the playlist…
I’m sure Slak Jaw will correct me if I am wrong
When i analyse tracks within playlists, folders etc. The system only analyses ones needed to be done and bypasses ones that have been analysed. If I have quite a lot tracks in a folder, not all tracks will get analysed first time. I may have to analyse a few times for all to done. Tracks get bypassed if already analysed.
OK, good to know so what should happen is if I add a load of different tracks in a load of different playlists all I need to do is go to my main music folder press analyze, and it should only analyze the new tracks.
Just to be safe though, I think what I will do is a analyze me folder that I later delete
