Anchor BeatGrid Marker Freezes App
  • Device model *((14-inch, 2021)
  • Version of operating system *(12.3
  • Version of djay *(5.26
  • Hardware/controllers used *(Pioneer DJM900 + CDJ 3000s
Adjusting the beatgrid with anchor point is causing the App to freeze both offline and while connected to controller or mixer music still plays but everything freeses
Select a song and then Adjust the grid on the one with an anchor as the reading im getting from default is way off so i remove the default beatgrid by adding an anchor to correct the tempo and the rest of the grid.
Hi @Owe_Marley, thanks for the details about your setup and the issue - this is very helpful!
  1. Have you rebooted your Mac recently?
  2. Are you running any other applications in the background or perhaps an iCloud backup?
  3. Are you using the latest Pioneer firmware for the DJM900 and CDJ3000s?
  4. Can you please try to capture a short video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Thank you for the quick response! Here are my answers:
  1. I haven’t shut down or rebooted my Mac in about a week.
  2. There are no extra applications running in the background.
  3. I’m using the latest firmware.
  4. Sure, I’ll try to screen record the issue since I was able to replicate it twice.
Hi @Owe_Marley, I recommend that you reboot your Mac regularly and definitely before DJing to maximize performance. Please try this and test again. If the issue persists, please try to capture a video. Thanks!
