Android problems. During playback, the track skips backwards on its own.
  • Device model: Xiaomi 13T
  • Version of operating system: Android 14 UP1A.230905.011
  • Version of djay: 5.2.9
Have you had this happen and how did you solve the problem?
I decided during my set in a club to use djay pro on my Android phone - Xiaomi 13T.
I uploaded tracks in flac format to the phone.
The program plays them. Everything is fine. But occasionally there is a moment when the track is playing, but then the playback resets and the track jumps back to a certain area.
At the same time, the display of the sound wave disappears.
This happened with different tracks.
I decided to use mp3. The result is the same. This can happen on some tracks.
Does anyone know where the track analysis cache is located on Android so I can delete it and analyze the tracks again? Maybe that’s the problem?
But for myself I realized that I will not risk to play from Android phone anymore because it is dangerous and the program works badly. Plus very reduced functionality compared to iOS.
Don’t make my mistakes.
Hi @Zirrex, thanks for the details about your setup and the issue. Sorry to hear you’re experiencing this issue. Since this sounds repeatable, can you please try to capture a short video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Android version is perfect. I use it with flac all day every day
It’s hard for me to catch the error and record the video. I’ve tried two different Android phones and a Android tablet. The error repeats. Plus, there are a number of other errors on Android, but I didn’t report it because I decided to try the iPhone 12 Pro for djay pro and there are no such errors. Everything works well, except for some ticks with automatic blending and the Tempo Blend option.
Understood @Zirrex. We will be releasing another major update soon, which should improve things. So, please retest after the next update and let me know. Thanks!
Hi @Zirrex, are you still experiencing this issue with the latest release?
I’m sorry, but I haven’t tested this bug since the update 5.3.1
But I will be testing. I will see if this error will be repeated.
