Android support for Hercules Inpulse 200 mk2/mk3
I mix using an FLX4, Hercules DJControlMix/Ultra, and a friend lent me his GRV6—all the features work perfectly on Android (CUE, Stems, Preview, etc.).
I’d like to know if it’s possible to add the new DJControl Impulse 200 mk2 and mk3 controllers, since they’re perfect controllers thanks to their portability.
I’ve tried copying the .djayMidiMapping file from my iPad, but Android won’t let me copy it to the DATA folder.
Hi @Lacoda, custom MIDI Mapping is not currently supported on Android and you cannot use the mappings from other platforms.
There’s an existing suggestion topic for this if you’d like to go upvote it:
