Android users: Playlist creation Finally
My Djays i have discovered the best and easiest way to create playlists on Android.
It all came down to the extension, which Djay could understand M3U
  1. Download Poweramp music player. (There is a free version, but i would recommend a pro version of this app as I’ve been using it since 2015 :blush:)
  2. Create your cool playlists there
  3. Go to Settings and search for playlists.
  4. In that playlist page, you should see a button to Export.
  5. Change the directory to your music folder or where you store music.
  6. Hit export. …. Done!!!:blush::blush::fire:
  7. Open our lovely app, Djay Pro…go to Playlists…..Enjoyyyyyyyyyyyy
Thanks for sharing @LeoTech
